EmpirBus™ - How to Manually Set BUS ID on a Membrane Panel 8BP (NXT)
Press and hold button 7 for about 20 seconds whilst applying power
Press button 8 three times, now a number will be displayed instead of also flashing, this is the base address
Use the button 5 and 6 to step down and up the base address
When the new base address has been set press and hold button 7 again for about 20 seconds to store
The way the base address is displayed on the membrane panel is as follows:
Indication on button 1 is 0 or 1, 0 when off, and 1 when lit
Indication on button 2 is 0 or 2, 0 when off, and 2 when lit
Indication on button 3 is 0 or 4, 0 when off, and 4 when lit
Indication on button 4 is 0 or 8, 0 when off, and 8 when lit
Indication on button 5 is 0 or 16, 0 when off and 16 when lit
Indication on button 6 is 0 or 32, 0 when off and 32 when lit
Indication on button 7 is 0 or 64, 0 when off and 64 when lit
Indication on button 8 is 0 or 128, 0 when off, and 128 when lit
The base address will be the sum of the indicators lit up
For Example, if Indication on Button 1 + Button 3 => Address is 1+4 = 5.
