Below is a list of articles that will help you get started with, and get the most out of, your new Garmin tactix® Delta Solar watch.
How Do I Get Started?
Before getting started, we recommend that you fully charge your tactix Delta Solar watch. See Charging the Device to learn how.
| 1. Power on the tactix Delta Solar by holding the Light button. | Click Here to Learn About the Buttons
| 2. Choose your language by scrolling through the list, use with the Start/Stop button to select your language. |
| 3. Pair your watch with your smartphone following the on-screen instructions (optional). | Click Here for Help With Bluetooth Pairing |
| 4. The next steps allow you to set your user preferences, simply follow the on-screen prompts to complete the setup process. |
How to Record Your First Activity
To start using activities, choose your preferred activities.
| 1. Press the Start/Stop button |
| 2. Locate your activities by using the Up or Down buttons to scroll through the list. Press Start/Stop button to select the activities |
| 3. Use the Down button until you see Done on the screen. Press the Start/Stop button to save your selections |
Tip: If you want to add activities, see: How to Add an Activity to the Garmin tactix Delta Solar
Other Articles You Might Find Useful
