"No Detailed Maps Found That Support Routing" or "Map data is not available" Error Message
There may be a problem with the mapping files if the message “No Detailed Maps Found That Support Routing” is displayed after turning on an automotive device. The message “Map data is not available” may display when searching for a destination. This may cause the device to show only the locations of major cities or major highways with no side streets.
To Correct This Issue:
See the detailed video below to troubleshoot this issue.
Windows
Mac
- Ensure Garmin Express is up to date and reinstall the maps
- See Garmin Express not Working for Updates and Downloads if the install does not complete.
For “No Detailed Maps Found That Support Routing” - if it cannot be dismissed by pressing OK or the back button, press and hold your finger on the message to clear it
If the device displays "Can't Unlock Maps" after clearing the message, follow the instructions in Correcting the Message "Can't Unlock Maps" or "Can't Authenticate Maps" on a Garmin Automotive Device
Ensure the map is enabled on the device by following the steps below if the device is not showing map detail.
1. Touch the Settings wheel
2. Touch Navigation
3. Touch Map and Vehicle
4. Touch myMaps
5. Enable the maps
- The map is enabled if a checkmark is present.
- Touch the empty box if a checkmark is missing.
- See the additional troubleshooting below if the map is missing or the page is blank.
6. Touch OK
Additional Troubleshooting if the Map is Missing From the Device or was Already Enabled:
- Ensure the memory card is inserted and formatted properly if the maps were installed to a memory card.
- See the video below for steps to properly insert the memory card
- See Formatting a microSD/SD Memory Card for instructions
- After formatting:
- Reinstall the map on the device
- After formatting:
See Troubleshooting Wireless Updates on the Camper/RV 785, dēzl™ 780, dēzlCam™ 785, or Overlander® if you encounter issues updating via Wi-Fi.
