1. Select the desired video or photo in the Garmin Drive App
2. Select the desired camera view
3. Trim the video as desired by touching and dragging the brackets on either side of the timeline. Skip this step for photos. Then touch Continue.
4. To Export with Picture-in-Picture, select the camera view you want to add. If you only want to export a single video, select None. The Export may take several minutes depending on the length of the clip.
NOTE: To change the position of the Picture-in-Picture touch the corner where you would like the picture-in-picture to appear
5. The video will now be exported and saved to your phone. You can Share the video or Remove From Camera if desired.
