Exposure Value Setting on the Garmin Dash Cam Tandem
Exposure Value Settings can be adjusted for the Garmin Dash Cam™ Tandem using the Garmin Drive™ app.
  • This allows you to make the image lighter or darker
  • The front-facing and internal-facing lenses can both be adjusted
  • The default setting is 0
  • -1 is the darkest and +1 is the brightest
To Adjust the Exposure Settings in the Garmin Drive App:
1. Open the Garmin Drive app
2. With your dash cam connected, touch the gear/wheel (settings) in the upper right corner
3. Select the Vehicle, then select the Dash Cam Tandem
4. Select the Front Lens or Interior Lens
5. Touch Exposure Value
6. Touch the preferred exposure value to save it
