USB Flash Drive Size Limitations/Not Enough Space for an Acura NSX Navigation System
The Acura NSX Navigation System update requires a 16GB USB flash drive. Using a USB flash drive smaller or larger than 16GB can cause the map update process to be unsuccessful. The following error message may display: "There is not enough space on the device to install the map update from USB storage device."
Related
