Transferring Garmin Quickdraw™ Contours
To transfer Quickdraw™ Contour files from one chartplotter to another:
- Simply insert the micro/SD card where the Quickdraw™ Contour files are stored in to the desired chartplotter; the files will automatically display
Personal Quickdraw™ Contours can not be transferred from one fishfinder or chartplotter to another through the ActiveCaptain® app.
See the "Related Content" for how to share personal Quickdraw™ Contours to the Quickdraw™ Contours Community as well as how to download Quickdraw™ Community content through the ActiveCaptain® app and transfer Quickdraw™ Community content to a compatible fishfinder or chartplotter.
Users can transfer Quickdraw™ Contours from one micro/SD card to a different micro/SD card or from a chartplotter to a different chartplotter through micro/SD card.
NOTES:
• Do not transfer Quickdraw™ Contour files onto a micro/SD card that already has existing preprogrammed charts or cartography as this may damage existing data on the micro/SD card.
• Only Quickdraw™ Contours can be transferred onto a different micro/SD card. Preprogrammed or built-in charts or cartography cannot be copied or transferred to another micro/SD card using this method.
• Transferring Quickdraw™ Contours through micro/SD is not a feature of the STRIKER series.
To transfer Quickdraw™ Contour files from one micro/SD card to different micro/SD card:
Insert the micro/SD card with the users Quickdraw™ Contours into a laptop / desktop computer micro/SD card slot
Identify and open the drive associated to the micro/SD card
Select the GARMIN File
Copy the entire GARMIN File
Paste the GARMIN file onto the other micro/SD card
