How To Test Fusion® Speakers with a Digital Multimeter
When troubleshooting a Fusion® speaker or subwoofer, resistance may need to be tested to check for shorts or connection issues with the speaker. This will require a multimeter.
- Turn off to the Fusion system including power the stereo and any external amplifiers
- Disconnect the speaker or subwoofer from the stereo or external amplifier
- Set the digital multimeter to measure resistance, or Ω Ohms
- Touch the negative and positive probes directly to the speaker or subwoofer terminals
- Allow the multimeter to read and settle on a steady reading
The result should be within range of the speaker or subwoofer specified resistance. For 4Ω speakers this would range between approximately 3.4Ω - 4Ω, for 2Ω speakers this would range between approximately 1.7Ω - 2Ω. If the reading is drastically outside of these ranges, or the digital multimeter reads an Open Line, that would indicate either a short (reading too low) or broken connection (reading too high) within the speaker or subwoofer. In either of these cases the speaker or subwoofer will need to be replaced.
