Pairing a GPSMAP 67i With the Garmin Messenger App
NOTE: This article is intended for users who have already activated an inReach® subscription for their GPSMAP® 67i outdoor handheld. If you have not yet activated an inReach subscription for the device, see - How to Activate a GPSMAP 67i in the Garmin Messenger™ App.
The Garmin Messenger™ app is an Android and iOS mobile application that optimizes inReach® messaging to use the cellular connection of your compatible smartphone when it is available, then switches to 100% global Iridium® satellite connection with a compatible inReach device when you go beyond available cellular coverage range. It also allows you to control and customize certain functions and settings for the connected inReach device.
When you first set up the Garmin Messenger app, you are prompted to verify your mobile phone number on the mobile phone that will be used. From that point on, any inReach messages sent to your phone number will be routed to the Garmin Messenger app instead of your phone's default text messaging app.
The GPSMAP 67i handheld can be paired with one smartphone at a time, and the software on the GPSMAP 67i handheld may need to be updated before it can be used with the Garmin Messenger app. For instructions, see - Updating the Software on Your GPSMAP 67i
1. Setting up the Garmin Messenger App
null
2. Pairing the GPSMAP 67i Handheld
In the Garmin Messenger app, select the profile icon or
in the top left.Select Add Device (or Devices > Add Device).
Allow any app permissions when prompted.
When powering on the GPSMAP for the first time, you will be prompted to select a language, then activate, and it will automatically start looking for the Garmin Messenger app.
If you had skipped this previously, you can enable pairing mode from the main menu on the GPSMAP by selecting Setup > Bluetooth > Continue.
If your GPSMAP is currently connected with another Garmin app on your phone, skip to step 5.
In the Garmin Messenger app, select Connect It and enter the 6 digit code from the GPSMAP when prompted.
