Difference Between Garmin® Marine Network Cables and Standard Ethernet Cables
Garmin® Marine Network cables are constructed very differently from standard Ethernet cables. A summary of the differences are provided below:
Garmin Marine Network cable:
  • External ground
  • Crossover wiring
  • Shielded cable
  • IPX7 Water resistant
  • Built in Drain Wire
  • The Garmin Marine Network cable uses the same Tx/Rx pairs for data transmission and also utilizes the unused pins (4, 5, 7 & 8) for power control of the various devices on the network
  • BI_DA+ : Transmit Positive BI_DB+ : Receive Positive
  • BI_DA- :Transmit Negative BI_DB- : Receive Negative
Standard Ethernet cable:
  • Internal ground
  • Parallel wiring
  • No shielding
  • Non-water resistant
  • Crossover cables allow similar devices to speak to one another. (Garmin units)
  • Also to link multiple GMS 10’s to create a wider network
  • A Standard Ethernet cable uses pins 1, 2, 3 & 6 for network data, using one pair for Tx and the other for Rx as shown in the diagrams above. The remaining pins are unused
Even though a Standard Ethernet cable can be used on the GPSMAP® 4000 series and newer we only recommend using Garmin Marine Network cables.
