Lily 2 Active Battery Life Assumptions
The battery life of your Garmin watch may be affected by how you use the watch. The information in the tables below is intended to outline the conditions used to determine the battery life specifications. Usage beyond what is listed below, or usage of features not listed, may result in reduced battery life. The information presented below is reference-only guide for general use of the Lily® 2 Active watch.
The following usage assumptions were used to determine the estimated battery life for the Lily 2 Active. Unless otherwise stated, all default software settings and configurations are assumed for the battery life specifications.
Notifications per Day | 50 |
Number of Interactions per Day | 32 |
Device-Generated Alerts per Day (Move or Goal Alerts) | 9 |
Hours per Day Outside of Bluetooth Range of Phone | 1 |
Display Brightness & Timeout | Default Settings |
Watch Face1 | Default |
Average Number of Hours Spent Outside per Day2 | 2 |
Number of Gestures per Day | 550 |
Pulse Ox Mode | Disabled by Default |
Number of Timed Activities | 0 |
Smartwatch Mode Battery Life | Up to 9 days |
Number of Interactions per Hour | 10 |
Minutes of Interaction Post-Activity | 1 |
Number of Gestures per Hour | 100 |
Assumed Temperature Range for Battery Life Specifications | 10C – 40C |
GPS Mode Battery Life | Up to 9 hours |
1 The “default” watch face is the watch face present on the device when it is taken out of the box. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
2 The Lily 2 Active utilizes an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the device outdoors in bright environments may reduce battery life.
