Embedding inReach Data on a Third-Party Website
The inReach® system allows multiple methods to import your inReach data into your website or web service. You can use the KML Feed, iFrame or our documented IPC API. Use of this API is limited to Professional accounts only: https://developer.garmin.com/inreach-portal/download/.
KML Feed:
Use the information within About inReach KML Feeds to import the inReach data into your website.
iFrame:
Use the code snippet below to insert the MapShare™ tracking into your website.
<iframe src="https://share.garmin.com/ShareName" frameborder="0" marginwidth="0" marginheight="0" width="810" height="760"></iframe>
IPC (inReach Portal Connect):
The inReach Portal Connect API can programmatically receive or send information to an inReach device. Please contact the Professional Sales Team for additional information here: https://www.garmin.com/forms/inReachProSales/
