PS22 Orientation
The Panoptix™ PS22-TR transducer provides either LiveVü™ Down sonar or LiveVü™ Forward sonar. The transducer physically rotates to provide either a down image or a forward image. With correct settings, the chartplotter and transducer automatically set the orientation mode.
  • Auto Stabilization found under the sonar menu needs to be turned ON
  • Orientation found under the sonar menu should be set to Auto
  • Transducer when in water uses the Auto Stabilization feature to detect orientation
  • A digital depth lock is acquired*
After the Auto Stablization feature is turned on and once the digital depth are acquired, the chartplotter sets the orientation to the proper mode.
LiveVü Down Mode - Angle the transducer down        LiveVü Forward - Angle the transducer forward and slightly downward
PS22 LiveVU Down              PS22 LiveVU Forward
*Software must be above 7.00
