(2017) Service Alert 1681: Garmin Navigation Database Cycles 1612 and 1613 at Airport KGGG
PRODUCTS AFFECTED:
Garmin G900X, G950, G1000, Cirrus PerspectiveTM, Embraer ProdigyTM, G2000, G3000, G5000, Embraer Prodigy Touch, GTN 6XX/7XX, and GNS 400W/500W systems using Garmin Navigation Database cycles 1612 and 1613 are affected.
ISSUE:
Garmin Navigation Database cycles 1612 and 1613 contain incorrect lateral guidance at VOR/DME RWY 31 PODCI transition at airport KGGG. Using cycles 1612 and 1613 at KGGG may also result in an unresponsive MFD.
NOTE
EIS and PFD functions are not affected.
PILOT ACTION:
Do not use the PODCI transition for VOR/DME RWY 31 at KGGG. After landing, power cycle the MFD if it is unresponsive.
RESOLUTION:
This issue will be resolved in Garmin Navigation Database Cycle 1701.
