Installing the Latest Software On the Descent Mk2 Series
null
null
We are frequently adding new features with the latest software updates. For a complete list of changes see the Change Log below.
Change Log
System Software July 2025 Release Notes v28.00
This update is starting to roll out to users on July 15th and may take up to a week before reaching your device. After updating you may be prompted to accept the dive disclaimer again.
Improvements and Bug Fixes
  • Added support for the S1 SubWave Buoy.
  • Fixed an issue with Dive Time SubWave messages with times over 4 hours.
  • Fixed an issue where a portion of the surface interval time could be cut off on certain watch faces.
  • Fixed an issue where Kill Switch was not available as a hotkey.
  • Fixed Garmin Pay indicating the wallet was locked too soon.
  • Merged in the latest Fenix 6 Pro Q1 2025 content, including support for YouTube Music and other bug fixes and minor improvements.
Previous Software Version Change Logs
26.10
  • [In-Dive Change] Added the Diver-to-Diver distance feature. See our FAQ Setup and Use of the SubWave Diver Distance Feature
  • Added the ability to rate Connect IQ applications from the app settings menu.
  • Added Obstacle Course Racing activity. See What Is the Obstacle Racing Activity Profile?
  • No longer allow including other divers’ tanks in SAC rate calculations
  • Added a prompt when adding a diver’s own tank to include it in SAC rate calculations
  • Improved safety stop and deco stop ceiling graphics
  • Fixed issue where Gas Consumption data could appear in Apnea dive logs
  • Fixed issue in Swimming activities where distance could be stuck at zero
  • Improved algorithm for calculating calories burned in Swim activities.
  • Improved voice prompts played during activities.
  • Updated Altitude Acclimation widget to now show altitude acclimation as a percent.
  • Updated the Golf activity to now allow users to disable the auto-lap notification when recording the activity.
  • Updated the inReach app to prompt the user when the inReach device is out of range when tracking is toggled on.
  • Fixed a possible issue that would cause the device to shut down when editing a set in the strength activity.
  • Fixed a possible shutdown that would occur when receiving smart notifications during an activity.
  • Fixed a possible shutdown when selecting a PacePro plan.
  • Fixed a potential issue where connecting headphones while shuffle playing music would cause the device to restart the playlist.
  • Fixed an issue where setting the default battery mode for an activity would not change the current battery mode of the current activity session.
  • Fixed a potential issue causing CIQ watch faces to fail to load.
  • Fixed a potential issue causing device shutdowns in strength activities.
  • Fixed an issue where the device would not exit Battery Saver Mode after charging fully.
  • Fixed an issue where the device would not show all saved waypoints on the waypoint list.
24.00
  • [In-Dive Change] (Mk2i Only) Added support to receive Diver to Diver Messages. You must both have updated (v2.23) Descent T2 Transceivers and be paired to each other to be able to receive messages.
  • [In-Dive Change] (Mk2i Only) Added support to receive Diver Assistance alerts. You must both have updated (v2.23) Descent T2 Transceivers and be paired to each other to be able to receive assistance alerts.
  • Fixed issue with Dive Big Numbers Mode animations when tapping to scroll.
  • Fixed an issue that could prevent updating to the latest Dive Sites database. If your dive sites have disappeared, please reconnect to Express to download them again.
  • Merged in latest Fenix 6 Pro 2023 content
22.30
  • [In-dive Change] (Mk2i Only) Added a Divers menu to the main menu during dive activities. This page allows you to view other divers’ tank pressures and depths.
  • [In-dive Change] In the compass menu, "Reset Heading" has been renamed to "Change Heading".
  • [In-dive Change] Improved Apnea activities to always show depth to a tenth of a meter, even below 100m.
  • [In-dive Change] Improved Multi-Gas to always show the PO2 field, even if the current gas is air.
  • (Mk2i Only) Added support for Descent T2 transmitters.
  • (Mk2i Only) Added support for public tank names, with supported Descent T2 software (2.05 or later). The name you assign to a transmitter is now visible to other divers when they pair, to make it easier to pair to the correct devices. When connected to another diver's transmitter, you can instead set a personal nickname for that transmitter. This isn't currently available for Descent T1, so they will continue to show the Device ID (numbers), as will Descent T2 devices with older software.
  • Added support for discarding Apnea activities. Apnea and Apnea Hunt no longer care about Pool Mode.
  • Added support for device backup and restore. Device backups happen automatically unless disabled, and upload to Connect for storage. You can apply a backup when setting up a new device or after resetting an existing Mk2 or Mk2S. If you purchase a Descent Mk3, you can migrate many of your settings forward from Mk2. For best results, make sure both devices are fully updated first.
  • Improved the ordering of the surface menu in Apnea activities.
  • (Mk2i Only) Improved how transmitter units are stored. Rather than PSI/Bar being set per-transmitter, there is now one setting for all transmitters.
  • (Mk2i Only) Improved transmitter software update prompts to occur at a more appropriate time.
  • (Mk2i Only) Fixed an issue where the main dive page would show a full tank if a transmitter was in a NO COMMs state.
  • Fixed an issue that could cause an incorrect warning about outdated watch or transmitter software when entering a dive precheck page.
  • Fixed the Obstacle Course Racing app being unavailable to add.
  • Fixed being unable to create courses on-device.
  • Fixed headphone names being blank in the sensor list.
  • Fixed an issue with the Spotify app always pushing the library page instead of the music control.
  • Brought Descent Mk2 up to date with Fenix 6 version 26.82 (from 25.10).
  • Fixed issue related to updating T2 software
  • Fix issue when changing to Russian language
Change Log (for Sensor Hub)
    • WHR improvement
    • SpO2 bug fix
18.30
  • CIQ security fixes and improvements
18.10
  • [In-dive Change] Added Big Numbers mode for the Single- and Multi-gas dive modes: Enable this feature by toggling on Single-Gas Settings > Big Numbers or Multi-Gas Settings > Big Numbers
  • [In-dive Change] Fixed last deco stop depth display when the “Last Deco Stop” setting is set to 4.5 meters
  • [In-dive Change] Apnea dives will now automatically end within 1 second of the diver surfacing instead of 5 seconds of the diver surfacing
  • Improved display of the dive temperature chart
  • Fixed issue with editing high/low speed Dive Alerts when utilizing metric units
  • Fixed issues with Dive Alert preview functionality
  • Fixed issues with Apnea Surface Interval Alert’s sound and vibe settings
  • Fixed issue with certain languages showing “?” for some translated text
  • Brought Descent Mk2 up to date with fenix 6 version 24.10:
    • Added Backcountry Snowboarding activity.
    • Added Exercise Load graph.
    • Added a new Settings shortcut Hot Key and Power Control.
    • Added a prompt to end Resume Later for an activity when user is near their sleep window.
    • When an incident is detected by your watch, a message appears on your watch and phone, and an automated message is sent to your emergency contacts. You can cancel the message from either device.
    • Updated altimeter calibration to use weather forecast data to improve calibration.
    • Fixed UI bug issue with the Recovery Widget.
    • Fixed UI bug with battery icon in the inReach Widget.
    • Fixed an issue on the Dog Tracking widget where distances would only display in yards, and never in miles.
    • Fixed an issue for Elliptical activities when saving custom workouts.
    • Fixed an issue where Swimming Personal Records would not save when the pool is set to 33 and 1/3 meters
16.00
  • [In-dive Change] Improved PO2 alerts to prevent repetitive nuisance alerts.
  • [In-dive Change] Added the Neutral Buoyancy alert that fires when reaching a customizable depth. This is defaulted on at 30 feet / 10 meters.
  • Added advanced Apnea alerts
  • Added the Target Depth alert that fires when reaching a goal depth.
  • Added a Variometer alert that provides audible and/or vibration feedback about your ascent/descent speed.
  • Added the High and Low Speed alerts that fire when you’re ascending or descending outside of a set speed range.
  • The Surface Alert has been converted to use this new system, and is now located under Dive Setup > Apnea Alerts.
  • The apnea and scuba alerts have been split into separate menus under Dive Setup.
  • Added the Ascent Rate field as an option to the gas/gauge dives that shows the current ascent or descent rate in ft./min. or m./min.
  • Improved display of surface interval times to max out everywhere at 999 days.
  • Updated "Deco PO2" to "MOD/Deco PO2" to help clarify what that setting affects.
  • Surface pressure will now be reset automatically if the watch is still in a dive when it’s connected to a computer. (Holding Up during power-on still works too.)
  • Fixed an issue where “exit location” may not be available in the post-activity menu.
  • Fixed an issue on the CCR pre-dive check where a 2nd diluent gas would be shown as an open circuit gas as well.
  • Fixed power calculations while using an HRM-Pro in Cross Country Ski activity.
  • Fixed instability that could occur when reviewing a multisport activity.
  • Pulled in fenix 6X/s Pro changes from version 22.10 through version 23.10. This includes several features including a refresh of the the Training Status glance, eBike support, and many bug fixes and stability improvements.
14.10
  • [In-dive Change] - Fixed CNS calculations at PO2 levels above 1.65
  • Added new Apnea fields for surface and in-dive screens
  • Added a Gas Calculator tool to the Dive Planning app
  • Added a warning to the NDL calculator in the Dive Planning app when the planned depth exceeds the MOD of the breathing gas
  • Added support for Sail and Sail Race activities
  • Added new app and power control: Reference Point - Reference Point provides simple bearing and distance information to saved locations, dive sites, and your previous dive’s entry and exit locations (if available).
  • Improved Apnea apps to continue to search for the first GPS entry location throughout the dive session.
  • Fixed the inReach disconnection warning popup from occurring during dives
  • Fixed being able to add diving screens to the Bouldering app
  • Fixed issue with the inReach widget where it showed more battery bars than possible
  • Fixed an issue that could prevent certain ANT bike speed sensors being updated
  • Pulled in fenix 6X/s Pro changes from version 20.50 through version 22.10. Major new features include support for CIQ System 5, the Horseback Riding activity, and Strength 2.0.
12.20
  • [IN-DIVE CHANGE] Fixed the CCR app showing a popup when the diluent’s PO2 was over the PO2 critical limit, when not bailed out.
  • [IN-DIVE CHANGE] While on the surface at the end of the dive, NDL will be replaced with the time until the dive saves (unless there is an alarm active or a deco/safety stop is required).
  • [IN-DIVE CHANGE] The safety stop broken alarm will no longer fire again if it already fired in the last 10 seconds.
  • [IN-DIVE CHANGE] The main dive screen will now continue to display the (paused) safety stop timer if above a missed safety stop, instead of displaying NDL time.
  • [IN-DIVE CHANGE] Added the ability to save and quit a dive early if on the surface, by selecting Stop Dive in the menu.
  • [IN-DIVE CHANGE] [Mk2i only] Added a second page to the Subwave network screen, showing approximate depths of other divers in the network.
  • [IN-DIVE CHANGE] Completely reworked the Apnea and Apnea Hunt apps: The in-dive screen and up to 5 surface screens are now customizable. The data screens have been reset for these two apps.
  • Pulled in changes from fenix 6X/s Pro through version 20.50. Major new features include the Adventure Race app, Sleep Score by Firstbeat, and updates to Garmin Pay.
  • Added the ability to view hang time, ascent, and descent statistics for Apnea dives in the dive log.
  • Added the ability to change the last decompression stop depth. You can now choose between 10/15/20 feet or 3/4.5/6 meters. This does not impact safety stops. This feature is also available in the Plan Dive app.
  • Added a “Pop-up” setting for dive depth and time alerts. Dive alerts with this setting off will tone/vibe and blink the depth or time field, but won’t show the normal popup. New alerts for Apnea/Apnea Hunt will default this setting to Off. Existing alerts, and new alerts for the other dive apps, will default this setting On.
  • Added a prompt to save if an Apnea/Apnea Hunt session hasn’t been saved 30 minutes after the last dive.
  • Added a simple stopwatch to the Apnea/Apnea Hunt surface loop.
  • Added the ability to delete the first CCR diluent, as long as there’s another one available.
  • Added the ability to access the main menu and the controls menu while on the dive screens, pre-dive.
  • Added the Surface Gradient Factor field as an option for gas dives.
  • Added support for searching Dive POI waypoints by name.
  • Added a notification if a software update is waiting to be installed when the watch is removed from a wall charger.
  • Added a new page to the Surface Interval widget to allow seeing detailed no-fly information, including when the timer will expire.
  • Dive logs can now be deleted like other activities. Deleting a dive may cause dive numbers to get out of sync until the next sync with Connect.
  • Improved the No-fly time calculation to follow DAN’s most recent guidance: Single-day no-deco dive is 12 hours. Repetitive or multi-day no-deco dive is 18 hours. Decompression dive is 24 hours. Only dives deeper than 15 feet and longer than 3 minutes trigger no-fly restrictions. Missed decompression or gauge mode: 48 hours, as before. You can change back to the previous flat 24-hour timer by using the
  • Dive Setup > No Fly setting.
  • Improved Apnea/Apnea Hunt to always use every-second recording, regardless of the Data Recording setting.
  • Improved how Apnea activities calculate Time Out.
  • Improved how the temperature plot y-axis scales in the dive log.
  • Improved the dive alert menus to no longer show the “Alert Added!” popup every time a new dive alert is added.
  • Renamed Bottom Time to Dive Time in the dive log for clarity.
  • Fixed an animation issue that could cause intermittent excessive battery drain.
  • Fixed a potential UI responsiveness issue when wireless communication is disabled.
  • Fixed a potential crash when using the Reset Surface Pressure prompt.
  • Fixed a potential crash when viewing a dive log synced from Connect.
  • Fixed an issue that could cause pulse ox to get turned on after using a Connect IQ app, causing high battery use.
  • Fixed an issue where divider lines may not turn red when in bailout mode in a CCR dive.
  • Fixed average depth in Gauge mode failing to update, if the watch was rebooted mid-dive.
  • Fixed the Tide app sometimes not drawing the chart correctly.
  • Fixed several localization issues.
  • Fixed VO2 Max being cleared on upgrade to 12.10.
  • If you've already updated to 12.10, you can recalculate your VO2 Max from activities stored in Connect: In Connect Mobile go to Device Settings > General and toggle Physio TrueUp off. Back out a page to save the setting. Go back to Device Settings > General and toggle Physio TrueUp back on. Back out and sync your device. This will download your physio metrics from Connect and re-set your VO2 Max.
10.00
  • Dive alerts with this setting off will tone/vibe and blink the depth or time field, but won’t show the normal popup.
  • New alerts for Apnea/Apnea Hunt will default this setting to Off. Existing alerts, and new alerts for the other dive apps, will default this setting On.
  • Pulled in changes from fenix 6X/s Pro through version 19.20. Major new features include the Adventure Race app, Sleep Score by Firstbeat, and updates to Garmin Pay.
8.40
  • [IN DIVE CHANGE] When TTS is over 99:59, it will now show time in minutes instead of capping at “99+”.
  • Fixed issue where the “Safe to switch to X” prompt could get cut off in certain languages.
  • Fixed issue causing intermittent excessive battery drain.
8.20
  • Brought in the changes made through version 15.20 of fenix 6S Pro. This adds the Ultra Run app, as well as several bug fixes.
  • Added another check for the depth sensor's health. Very bad temperatures will be considered a depth sensor failure and the "Do Not Dive" popup will appear (Temperatures don't factor in to generated dive profiles, but are an indicator that the pressure may also be bad.).
  • Improved how widget names are truncated on the reordering page, especially when using a language other than English.
  • Improved Bluetooth headphone connection stability.
  • Adjusted ANT connection parameters to improve sensor acquisition times.
  • Fixed an issue that could prevent doing a reset with the button combo on powerup.
  • Fixed a potential crash when using a paired inReach.
  • Fixed a potential crash in the Tides app.
  • Fixed an issue where the altimeter wouldn't update at the correct rate in an activity. This could cause stair-stepped elevation graphs, incorrect ascent/descent values, and poor performance in Indoor Climb/Bouldering activities.
  • Fixed an issue where Bottom Time was not recorded correctly in Apnea dives.
  • Fixed Save Location not working for dive entry/exit points.
  • Fixed battery drain issue after disconnecting from a paired inReach device.
  • Fixed invalid information appearing in the Dive Log widget when viewing a manually created dive synced from Connect.
Related
