Colorado Series Pairing Instruction for Garmin Speed/Cadence Bike Sensor (GSC 10)
You may need to pair your Garmin Speed/Cadence bike sensor (GSC 10*) after replacing the battery or when first using your Garmin GPS device with the GSC 10.
To pair your GSC 10 on a Colorado:
  1. Select Shortcuts
  2. Select Setup
  3. Select Fitness
  4. Press the Reset button on your GSC 10 (the white button)
  5. Wait for the Reset button to flash red/green
  6. Select Bike Cadence Sensor
  7. Select On
  8. Select Search for a Bike Cadence Sensor
  9. Pedal your bike to see alternating red/green blinks on the GSC 10 reset button
Bike Cadence Sensor will show Connected when pairing is successful. The Colorado will pick up cadence through the GSC 10. Speed will come from the satellites.
* The GSC 10 Speed/Cadence bike sensor has been discontinued.
