Types of USB Cables Used to Connect Automotive Devices to the Computer
There are three types of USB data cables used to connect Garmin automotive devices to the computer: mini-USB, micro-USB, and USB-C.
Locate the USB port on your device and reference the images below to know which USB data cable to use.
NOTE: Some of our devices have a powered mount and the USB port used for the computer may be located under the mount or in a different location. See Where to Connect the USB Computer Cable on Devices with a Powered Mount for more info.
mini-USB Port:
Some devices come with a USB data cable in the box when purchased new. A compatible mini-USB cable can also be purchased from Garmin's website
Micro-USB Port:
Some devices come with a USB data cable in the box when purchased new. A compatible micro-USB cable can also be purchased from Garmin's website.
Use a Garmin brand USB data cable to ensure the device communicates with the computer properly.
USB-C Port:
USB C Port 1
Some devices come with a USB-C cable that can be used to connect to the computer to charge it.  A compatible data transfer USB cable type A to type C can be purchased on the Garmin website.
If your computer also has a USB-C port, you can connect directly using a USB type C to USB type C data transfer cable without a converter cable. A compatible data transfer USB cable type C to type C can be purchased on the Garmin website.
Macs with only USB-C Ports:
Some newer Mac computers may only have USB-C or Thunderbolt ports. It is best to connect your device directly to the computer when possible. If your device has a USB-C port, you can use a USB Type C to Type C data transfer cable. Apple has a helpful support article that explains different USB types, how to identify them, and what adapters can be used: Identify the ports on your Mac and Adapters for the Thunderbolt 4, Thunderbolt 3, or USB-C port on your Mac.
Macs with M1 and Newer Chips and USB-C Ports:
Automotive devices with miniUSB or microUSB ports must use a USB-C to USB adapter along with the appropriate miniUSB to USB-A or microUSB to USB-A cable provided with the device.
Automotive devices listed below may need to use a USB 2.0 third-party hub in order for the Garmin device to properly detect the USB connection.
  • BMW Motorrad Navigator V and VI
  • Camper 760 caravan and motorhome sat nav
  • Camper 780 caravan and motorhome sat nav
  • Camper 785 & Traffic caravan and motorhome sat nav with camera
  • Camper 890 caravan and motorhome sat nav
  • Camper 895 caravan and motorhome sat nav
  • Camper 1090 caravan and motorhome sat nav
  • Camper 1095 caravan and motorhome sat nav
  • Can-Am Spyder zūmo® 590LM
  • dēzl™ 560 GPS navigator
  • dēzl™ 760 GPS navigator
  • dēzl™ 770 GPS navigator
  • dēzl™ 780 GPS navigator
  • dēzl™ LGV500 | dēzl™ OTR500 GPS navigators
  • dēzl™ LGV610 | dēzl™ OTR610 GPS navigators
  • dēzl™ LGV700 | dēzl™ OTR700 GPS navigators
  • dēzl™ LGV710 | dēzl™ OTR710 GPS navigators
  • dēzl™ LGV800 | dēzl™ OTR800 GPS navigators
  • dēzl™ LGV810 | dēzl™ OTR810 GPS navigators
  • dēzl™ LGV1000 | dēzl™ OTR1000 GPS navigators
  • dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
  • dēzlCam™ LMTHD GPS navigator with camera
  • dēzlCam™ 785 LMT-S GPS navigator with camera
  • dēzlCam™ LGV710 | dēzlCam™ OTR710 GPS navigators with camera
  • Garmin Catalyst™ Driving Performance Optimizer
  • Garmin Dash Cam™ 45
  • Garmin Dash Cam™ 46
  • Garmin Dash Cam™ 47
  • Garmin Dash Cam™ 54
  • Garmin Dash Cam™ 55
  • Garmin Dash Cam™ 56
  • Garmin Dash Cam™ 57
  • Garmin Dash Cam™ 65W
  • Garmin Dash Cam™ 66W
  • Garmin Dash Cam™ 67W
  • Garmin Dash Cam™ Mini
  • Garmin Dash Cam™ Mini 2
  • Garmin Dash Cam™ Tandem
  • Garmin DriveLuxe™ 50 GPS navigator
  • Garmin DriveLuxe™ 51 GPS navigator
  • Garmin Fleet™ 600 series
  • Garmin Fleet™ 700 series
  • Garmin Speak™ with Amazon Alexa
  • Garmin Speak™ Plus with Amazon Alexa with Built-in Dash Cam
  • Harley Davidson Roadtech zūmo® 590LM
  • nūviCam™ LMTHD GPS navigator with camera
  • Overlander® GPS navigator
  • RV 760 RV navigator
  • RV 780 RV navigator
  • RV 785 & Traffic RV navigator with camera
  • RV 890 RV navigator
  • RV 895 RV navigator
  • RV 1090 RV navigator
  • RV 1095 RV navigator
  • zūmo® 590 GPS navigator
  • zūmo® 595 GPS navigator
Macs with Other Types of USB Ports:
Connecting through a hub, USB extension cable, adapter, keyboard, or monitor is not recommended or supported.  Use the product compatible USB cable to connect directly to the computer.
Related
