Using the Fuel Prices Feature
The Fuel Prices feature can be used to search for gas prices and fuel types near you or a specific area. You must be connected to the Tread® App to use this feature. See Installing and Pairing the Tread App.
Content comes from user-generated sources via a third-party provider and may not match other Fuel Price apps.
Allows you to choose a fuel type to filter by.
Results display the last day updated.
The average duration between price changes is 3 days.
To Use the Fuel Prices Feature:
1. Touch Where To?
2. Touch Categories
- You may also search Gas Stations or a particular name into the Search field in the upper right.
3. Touch Gas Stations
4. Gas prices will automatically display nearby areas (unless you are searching in a different area) where data is available.
Not all gas stations will have prices available.
To change the fuel type, touch the Gas Pump Icon.
5. Select a Fuel Type and touch Save
- Regular is the default.
6. Select a location then tap the information icon (i) to show more details
7. View additional details including when the price was last updated, then tap Go
