Weather Overlays for Select Garmin Watches
Some Garmin® watches feature a weather app or widget glance that can provide additional weather map overlay information. This allows you to make more informed decisions since you can get detailed weather information on your watch. Weather overlay data will be retrieved via Bluetooth data connection to a smartphone. Phone location data access must be enabled for the Garmin Connect™ app in order to receive weather data on your watch. Depending on your location, some weather coverage information may not be available. If the weather data is incorrect or taking a long time to load see Weather Widget Displays Wrong Information on My Garmin Device for more information.
Viewing Weather Overlays
You watch has four different weather map overlays which will show precipitation, cloud cover, temperature, and wind speed and direction. When you access the weather map, the watch will attempt to connect to GPS in order to accurately display your location. If you see the blue triangle locator blinking or showing a question mark the watch has not acquired satellites yet. When the watch has locked onto GPS, the blue triangle will remain steady. If you are indoors GPS can take longer to acquire, or it may never locate you at all.
  1. Press DOWN until you locate the Weather widget glance.
  2. Press START to open the Weather glance.
  3. Press DOWN until you see the weather map screen.
  4. Press START.
  5. Select Change Overlay.
  6. Select an overlay.
Depending on your location, some weather information may not be available. Weather information is sent to the watch from a paired smartphone and requires a data connection.
From the weather map, press START and select Play to show weather conditions for the last hour. This can help you know which way the weather is travelling and how fast it is moving. You can also access the pan and zoom controls to view weather in other locations.
Examples of Weather Overlays
The examples below were taken from an epix™ Pro (Gen 2) - Sapphire Edition 42mm. What shows on your watch may vary based on display size and resolution.
Precipitation
Precipitation Map
Cloud Coverage
Cloud Coverage Map
Temperature
Temperature Map
Wind
Wind Speed and Direction Map
Compatible Watch List
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ Mk3 | Descent™ Mk3i
  • Enduro™ 2
  • Enduro™ 3
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition
  • epix™ Pro (Gen 2) - Sapphire Edition | epix™ Pro (Gen 2) - Standard Edition
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
  • fēnix® E
  • Forerunner® 945 LTE
  • Forerunner® 955 | Forerunner® 955 Solar
  • Forerunner® 965
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
  • quatix® 7 Pro | quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
