Change Holes Manually on My Approach S62
The Approach® S62 will automatically transition to the upcoming hole when brought near the hole's farthest back tee box. To make sure the transition takes place automatically, walk through the farthest back tee box before moving to the tee you will be playing from.
If for any reason the watch does not automatically transition, transitioning can be done manually.
Changing Holes Manually
  1. Press the action button.
  2. Select Change Hole.
  3. Select + or - to reach the desired hole number.
  4. Select Checkmark Icon to confirm hole selection.
NOTE: From the hole view, you can also drag the hole indicator around the edge of the screen to change holes.
The watch will revert to the hole view on that hole and move with your GPS position to determine distances.
