Can the Garmin Catalyst and Remote Cam Work on Battery Power Only?
The Garmin Catalyst must have power supplied through the powered mount in order to record a drive session. The Remote Cam receives its power from the powered mount when the mount is connected to the 12v or Hardwired cable and the Garmin Catalyst is in the mount. Without power to the mount the Remote Cam will not function and you will only be able to review your session data.
This Video is a Quick and Easy way to Learn about Installing and Powering your Garmin Catalyst and Remote Cam.
See Power/Charging Issues with the Garmin Catalyst or Remote Cam for troubleshooting help.
