1. Touch Apps
2. Touch dezl if necessary
3. Touch Trip Planner
4. Touch New Trip
5. Touch Select Start Location
NOTE: The Start Location is the first stop on the route. You can use your current location as the starting location, but it isn't necessary. The device will skip your current location if that is where you are when it begins to navigate.
6. Select the starting point using the search options
7. Touch Select
8. Touch Add Location to add a second point
9. Follow steps 6 through 8 to locate and add up to 30 total points. Touch a point to show additional options if changes need to be made.
10. Touch Select Destination and follow steps 6 and 7 to select a destination
11. Touch Next. The route will now calculate
12. Review the route on the map. Touch the back arrow if any changes need to be made. Touch Save if no changes need to be made.
13. Type a name for the route and touch Done
The trip is now saved to Trip Planner and can be found under Saved Trips.
