Verify Maps are Enabled on the Tread
The device will not be able to find any entered locations if the mapping is disabled.
To Enable the Mapping:
1. Touch Settings
2. Touch Map Display
3. Scroll down and touch Map Manager
4. Touch Manage Device Maps
    • Skip this step on some devices
Touch the down arrow to expand the map list.
5. If there is no checkmark, touch the empty box to place one. This will enable the map.
Your device should be able to locate destinations once the mapping has been enabled.
Try the Following in Order if the Errors "No Matches Found" or "Cannot Find Search Results" Continue to Appear when searching for a destination:
Current Map Version: 2026.10 (North America) as of February 12, 2025.
