Delta Inbounds Software Update
Software for your device should be kept up-to-date in order to take advantage of improvements and bug fixes. Updates are free and easy to install. To update the software on your device, please utilize the following method:
Garmin Express™
Garmin Express is needed in order to update the Base Unit or Dog Device. Garmin Express provides the ability to check and offer software updates automatically each time you connect your device to the computer. It is recommended to power the Base Unit with AC adapter or AA batteries for any Garmin Express updates. You can update the Delta Inbounds™ Dog Device as well by using the charging cable for that device.
To update the Base Unit, remove the back plate and next to where the batteries are inserted you will see the mini USB connection. Use the cable provided in the box to connect to your computer and download Garmin Express to check for updates.
Download Garmin Express for your computer
