Changing the GPSMAP 276Cx Map Page Data Fields and Layout
The GPSMAP® 276Cx handheld navigator can be customized to display different types of data on the Map page. Before you can customize the data fields, you must select a page layout that includes data fields.
Customizing the Page Layout
From the Map page, press MENU.
Select Set Up Page Layout.
Select a page layout with data fields:
Map with Overlay: Includes 4 data fields as a transparent overlay in each corner of the display.
1 Column (Large): Includes 4 data fields in a column on one side of the map.
1 Column (Small): Includes 5 data fields in a column on one side of the map.
Customizing the Data Fields
Select Change Data Fields.
Select a data field to replace.
Select the new data field.
