Select Track Manager from the main menu.
Select Current Track.
Select Clear Current Track.
Select Yes.
Clearing the Current Track or Clearing the Current Activity
Most Garmin outdoor handhelds are designed to record track points when powered on and connected to satellites. This is by design, to allow you to simply power the device on and begin your activity.
If you need to clear the current track or activity for any reason, follow the steps for your specific device model below.
NOTE: If Recording Controls, Track Manager, or Tracking is missing from the menu, see - Options Are Missing From the Main Menu on My Outdoor Handheld.
Select Yes.
From the main menu, select Tracking.
Select
Select Tracking Controls.
Select Discard.
Select Discard again.
From the app drawer, select Track Manager.
Select Current Activity.
Select
Select
Select Clear.
Press MENU twice to access the main menu.
Select Track Manager.
Select Yes or Clear.
Select Yes.
Select Yes.
Select Recording Controls.
Select
Select Discard.
Select Clear.
Select
Select Discard.
Toggle the items you with to clear.
Select Apply.
Select Clear.
From the main menu, select Track Manager.
Select
Select
Select Clear.
Select
Select
Select
Toggle the items you wish to clear.
Select Apply.
If Recording Controls is missing from the menu, see - Options Are Missing From the Main Menu on My Outdoor Handheld.
Select Yes.
- Select
Select
Select Clear.
Select
Select
Select Clear.
Select Yes.
Select Yes.
Select
Select
Select Clear.
NOTE: You can also reset the trip data to ensure the new track and associated trip data will coincide with each other. For steps on resetting trip data, refer to your owners manual.
