Why does the Fusion-Link Application Report "Error" when I Select "Update" from the Settings Menu?
Over-the-air software updates are only available for the Apollo Series. All other Fusion stereos require a USB stick loaded with an update folder connected to the stereo to perform an update. "Error" will display if there is no USB device connected, the USB device is not formatted correctly, or if the file is not in a folder named "update".
