D2 Air X10 Battery Life Assumptions
The battery life of your Garmin® watch may be affected by how you use the watch. The information in the tables below is intended to outline the conditions used to determine the battery life specifications. Usage beyond what is listed below, or usage of features not listed, may result in reduced battery life. The information presented below is presented as a general guide for reference only for the D2™ Air X10 aviator watch.
The following usage assumptions were used to determine the estimated battery life for the D2 Air X10. Unless otherwise stated, all default software settings and configurations are assumed for the battery life specifications.
D2 Air X10 Smartwatch Mode - Default Display Configuration
Notifications per Day90
Number of Interactions per Day160
Device-Generated Alerts per Day (Move or Goal Alerts)10
Hours per Day Outside of Bluetooth Range of Phone1
Display Brightness and TimeoutMedium and Long
Watch Face2Default
Number of Gestures per Day200
Average Number of Hours per Day Spent Outside15
Pulse Ox ModeDisabled by Default
Number of Minutes of Streaming Music0
Minutes per Day of Voice Assistant/Phone Call Usage0
Minutes per Day of Music Playback through Speaker0
Number of Timed Activities0
Battery LifeUp to 7 Days
D2 Air X10 Smartwatch Mode - Display Always On
Average Number of Hours per Day Spent Outside5
Watch Face2Default
Display TimeoutAlways on
 Battery LifeUp to 2 Days
D2 Air X10 - Activity Mode
Number of Interactions per Hour10
Minutes of Interaction Post-Activity1
Number of Gestures per Hour25
Display Brightness & TimeoutMedium and Long
Assumed Temperature Range for Battery Life Specifications10C-40C
Battery Life - GPS ModeUp to 24 Hours
Battery Life - GPS Mode + MusicUp to 6 Hours
D2 Air X10 - Activity Mode + Pulse Ox (Fly Activity3)
Battery Life - GPS Mode + Pulse Ox Up to 20 Hours
D2 Air X10 - Battery Saver Mode
Display Brightness and TimeoutLow and Short
Watch FaceDefault
Number of Gestures per DayDisabled by Default
Wi-Fi UsageDisabled
Music Playback Through Bluetooth HeadphonesDisabled
Music Playback Through SpeakerDisabled
Auto Activity StartDisabled
Minutes per Day of Voice Assistant/Phone Call Usage5
Battery LifeUp to 8 Days
1  The D2 Air X10 utilizes an ambient light sensor to automatically adjust the display brightness to an acceptable level depending upon the level of ambient light. Using the device outdoors in bright environments may reduce battery life.
The “default” watch face for the D2 Air X10 is the watch face present on the device when it is taken out of the box. The D2 Air X10 is designed to work with a variety of native watch faces as well as compatible Connect IQ watch faces. The usage of watch faces other than the default watch face may impact the battery life experienced in smartwatch mode.
3 WARNING: The SpO2 readings are intended for supplemental information only. Always defer to applicable flight instruments for primary awareness.
Related
