Using the Garmin GPS 152H Beyond the Polar Circles
The Garmin GPS 152H is a high-sensitivity GPS receiver with a built-in antenna, as well as a BNC connection to connect an optional external GPS antenna, such as the Garmin GA 38 Antenna.
Using either the internal or an external antenna, the GPS 152H does not support service beyond the polar circles. If taken into these areas, the GPS 152H may sporadically drop signal, or fail to acquire signal at all. Currently, there are no plans to add support for these areas to the GPS 152H.
