Garmin StreetPilot for iOS iPad Compatibility
The Garmin StreetPilot application is compatible with WiFi + 3G and WiFi + Cellular iPad models running iOS 9.0 or later.
It can also be used on the WiFi-Only iPad models running iOS 9.0 or later, however, an external GPS must be connected to use the application. The Garmin GLO is a Bluetooth GPS receiver that can be connect via Bluetooth to provide location data to iOS devices that do not have embedded GPS receivers, like WiFi-Only iPads.
You can learn more about, and purchase, the Garmin GLO here.
NOTE: The Garmin StreetPilot application is designed specifically for the iPhone. If you would like to have this app running fullscreen on your iPad, you will need to touch the ‘2x’ button on the bottom right to scale the application to the resolution of your iPad.
Effective May 14, 2018 Garmin StreetPilot for iOS is no longer available for purchase or download
