Can a GPS Antenna Connect to the AIS WatchMate® 750
Can a GPS antenna connect to the AIS WatchMate® 750?
The AIS WatchMate 750 Receiver does not have a built-in GPS receiver, no connection is supplied for an external GPS antenna. The AIS WatchMate 750 is designed to work with a stand-alone GPS Sensor or use a data feed from another GPS device on the vessel. The output from the GPS Sensor or another GPS device is connected to the NMEA input port of the AIS WatchMate 750.
