On some models, including Garmin Dash Cams with the exception of the Garmin Dash Cam™ Mini, Garmin Dash Cam™ Mini 2, and Garmin Dash Cam™ Tandem, the battery icon will have a lightning bolt in it, which indicates it is charging.
How Can I Tell Whether the Battery in My Automotive Device is Charging?
Note: The device is designed to be plugged in at all times. Even if the device is fully charged, it may not last on battery power alone for very long and the battery icon could become low fairly quickly.
For instructions on charging an automotive device, see the device's owner's manual.
The battery indicator will display in the top right corner of the Where To?/Main screen on your device. Select the following options for images on how this will look and details.
For Additional Charging and Battery Information See the Garmin Support Center:
Enter your product name in Garmin Support Center
Click in the Search for a solution... box under Choose a Topic
Type and search for keywords like the following
Why is the Battery on my Brand New Automotive Device Not Charged?
Low Battery Icon when Connected to a Computer
Using Third-Party AC Chargers, Cables, and Other Accessories with Garmin Automotive Devices
Charging Factors for an Automotive Device
Click on the relevant FAQ
