Dockside or Sea Trial Wizard Continually Populates after Completion or at Start-Up
If the Reactor™ 40 Autopilot system continually re-populates and asks users to re-accomplish the Dockside and Sea Trial Wizard, it is possible the Wizard was not completed, Speed Sources was not set correctly or another parameter of the Autopilot is not set correctly.
Follow these steps:
  1. Ensure the software is up to date
  2. Ensure the Speed Source is set properly
    • Go into Dealer Mode and select Speed Source > GPS SOG or to NMEA 2000 Tachometer (whichever is correct for the vessel)
  3. Ensure all the parameters of the Autopilot are correct
    • These could include Vessel type, Sources, Voltage, Drives, etc
  4. If steps one through three did not work, contact a certified Garmin® Marine  Installer or Technician to perform advanced diagnostic checks or contact Garmin Marine Product Support
Refer to the Owners Manuals for more information, and enter the name of the Autopilot system.
