Geocaches Not Appearing on an Oregon Handheld
There may be a few reasons why you cannot see the geocaches you have loaded to your Garmin outdoor handheld. This article covers the Oregon® outdoor handhelds.
Geocaches Too Far Away From Current Location
By default, your handheld only displays geocaches located within a 100 mile radius of the device's current location. If you have a poor or no GPS signal, ensure the device is outside with a clear view of the sky.
In order to view geocaches that are outside this radius, utilize the Search Near option and select a map point within a 100 mile radius of the geocache(s) you wish to view.
Using Search Near
Oregon 600 Series Handhelds
Open the application drawer by swiping:
Bottom to top (Portrait) -or-
Left to right (Landscape)
Select Geocaching.
Select .
Select .
Select Search Near.
Select an option for where the device searches from and follow the prompts.
Any loaded geocaches within 100 miles of the selected area should now be visible.
Oregon 700 Series Handhelds
Tap the Power key to reach the main menu.
Select Geocaching.
Select .
Select .
Select Search Near.
My Geocache Is Still Not Appearing on the Map
If your geocache is still not visible on the map, it is best to ensure the zoom level set for geocaches is not the issue. Map items do not appear when the map zoom level is turned off or higher than the selected level.
Checking the Geocache Zoom Level
Select Setup.
Select Map.
Select Advanced Setup.
Select Zoom Levels.
If Geocaches is set to Off, change it to Auto or a certain distance.
If Geocaches is set to a certain distance, go back to the Map page and use the +/- to get to that level.
Touch to open the Setup menu.
Select Map.
Select Zoom Controls.
Select Zoom Levels.
Clearing Geocache Filters
Remove any geocache filters that could be interfering with viewing the geocache.
Open the Application Drawer by swiping:
Bottom to top (Portrait). -or-
Left to right (Landscape).
Select Geocaching.
Select .
Select .
Select Show All.
Select .
Select Geocaching.
Select .
Select .
Select Show All.
Select .
My Geocache Is Still Not Showing
If your geocache still is not visible, it is possible the files are corrupt or did not transfer. Try deleting the geocache(s) from your device and adding them back.
