Resetting Edge 200
If for any reason the Edge 200 needs to be reset, use the steps outlined below. Only use this reset sequence sparingly and only when needed. The device being locked up or preferred to have factory default settings would be reasons to perform this reset.
To reset the Edge:
Power device off.
Press and hold Lap.
Power on device (still holding Lap).
Select Yes when Reset all settings to factory defaults? message appears.
The Edge 200 will power off and then back on. The device is now reset and is ready to be used once the initial setup is completed.
NOTE: Resetting the Edge 200 in this manner will only erase your user profile and settings. This reset will not erase the History or GPS data in the device.
