How Do I Change the Battery on the Running Dynamics Pod?
Changing the battery on your Running Dynamics Pod (RD Pod) will take about 5 minutes. You will need the following:
  • Your RD Pod
  • One CR1632 coin cell battery
  • A piece of tape, a magnet, or your fingernail
WARNING: Do not use a sharp object to remove the user-replaceable batteries. Contact your local waste disposal department to properly recycle the batteries.
Instructions to Replace the RD Pod Battery
  1. Remove the RD Pod from the flexible silicone clip by stretching the material around the pod.
  2. On the back of the RD Pod, twist the cover counter-clockwise to unlock it.
    Remove the battery compartment on an RD Pod
  3. Remove the cover and the battery. You can use your fingernail, a piece of tape, or a magnet to remove the battery from the cover.
    Remove the battery from the door of an RD Pod
  4. Wait with the battery out for 30 seconds.
  5. Insert the new CR1632 battery into the cover, ensuring the plus (+) icon is face down.
  6.  Replace the cover by aligning the dots to unlock, then rotate clockwise to the lock position as shown below. When properly closed, the cover should be fully seated and flush with the back of the pod.
    Replace the RD Pod cover
Replacing the Running Dynamics Pod Battery Video
