Editing Reps on Outdoor Multisport Watches
Using the rep count feature on a compatible outdoor watch will allow the user to track common gym exercises and count the number of reps completed. The watches use consistent motion to categorize exercises and display reps on the device.
Since each person’s form and exercise cadence is different, it is possible that the device may miss or count extra reps. In these situations, the band allows for the number of reps to be edited during rests between sets.
Rep Count Compatible Watches
  • D2™ Charlie
  • D2™ Delta | D2™ Delta PX | D2™ Delta S
  • D2™ Mach 1 | D2™ Mach 1 Pro
  • Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition watches
  • Descent™ Mk1 watch
  • Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S watches
  • Descent™ Mk3 – 43 mm | Descent™ Mk3i – 43 mm | Descent™ Mk3i – 51 mm watches
  • Enduro™ watch
  • Enduro™ 2 watch
  • Enduro™ 3 watch
  • epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition | epix™ (Gen 2) - Porsche Edition watches
  • epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition watches
  • fēnix® 5S | fēnix® 5 | fēnix® 5X watches
  • fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus watches
  • fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition watches
  • fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition watches
  • fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition watches
  • fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition watches
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition watches
  • fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition watches
  • fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition watches
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition watches
  • fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition watches
  • fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition watches
  • fēnix® E watch
  • Instinct® - Standard Edition | Instinct® - Tactical Edition | Instinct® - Esports Edition watches
  • Instinct® Solar - Standard Edition | Instinct® Solar - Camo Edition |  Instinct® Solar - Surf Edition | Instinct® Solar - Tactical Edition watches
  • Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition watches
  • Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition watches
  • Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition watches
  • Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition watches
  • Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition watches
  • MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer watches
  • MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2) watches
  • MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition watches
  • quatix® 5 | quatix® 5 Sapphire watches
  • quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar watches
  • quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro watches
  • tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition watches
  • tactix® Charlie watch
  • tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics watches
Editing Rep Count
  1. Start a Strength activity.
  2. Complete a set of reps.
  3. Press BACK (lower right button) to end the set.
  4. Press UP (middle left button) or DOWN (lower left button) to edit the amount of reps.
    • NOTE: Press and hold MENU if you missed the Edit option. You will then have the option to Edit Last Set.
  5. Press START/STOP (upper right button) to confirm the amount of reps.
  6. Press DOWN (lower left button) to edit the amount of weight.
  7. Press UP (middle left button) or DOWN (lower left button) to add or remove weight.
  8. Press START/STOP (upper right button) to confirm the weight and resume your rest period.
  9. Press BACK (lower right button) to end your rest and begin your next set.
  10. Repeat steps for each set as needed.
These steps will ensure that the correct number of reps are displayed on the device and are synced to Garmin Connect. The number of reps per set can also be edited in Garmin Connect after the activity is synced.
NOTE: While tracking a Strength Training exercise, it is common for the device to not display any reps counted until the device tracks up to 5 reps. In this situation, the watch will display “—“ until the device recognizes between 3-5 reps.
Related
