"The imported route(s) were calculated with different maps. Would you like to recalculate the route(s)?" message on a device
The message "The imported route(s) were calculated with different maps. Would you like to recalculate the route(s)?" may appear on a device capable of multiple-stop routing.
This message should only appear when a route was created in a mapping program (e.g., MapSource or BaseCamp) then transferred to a device using a different mapping version than was used in the program.
First, check which mapping version is installed to the device.
To see which map version is installed:
  1. Touch Settings
  2. Touch Map
  3. Touch Info
Then, when using BaseCamp (Windows) or MapSource, a drop-down menu will appear near the top of the window whenever more than one mapping product is installed to the computer.
To confirm the installed map when the drop-down is missing or when using BaseCamp:
MapSource:
  1. Open MapSource
  2. Click View
  3. Hover over Switch to Product
  4. Select the relevant mapset
BaseCamp:
  1. Open BaseCamp
  2. Click Maps
  3. Select the relevant mapset
Once the route has been created with the same mapping version, the message will no longer appear.
