- Go to https://www.garmin.com/software/baseCamp/.
- Scroll down the page and click Download Now under Windows Requirements.
- Click Download.
- Run the downloaded BaseCamp.exe file.
- If you are unable to find your download or your browser does not prompt to run it, with the web browser open, press Ctrl+J and select the file from your downloads.
- Follow the on-screen prompts to complete the installation.
How to Install or Update Garmin BaseCamp
Garmin BaseCamp™ is a free application for backing up and viewing data recorded with Garmin devices, updating device software, managing BirdsEye imagery and maps, and much more.
NOTE: Not all BaseCamp features are compatible with all devices.
BaseCamp software is only available for Windows or Mac computers and cannot be used on a mobile device, such as a smartphone or tablet. For more details on which Garmin devices are compatible with BaseCamp software, see - BaseCamp Compatibility With Garmin Devices.
Installing BaseCamp Software
BaseCamp software can only be installed to Windows and macOS, and is not supported by other computer operating systems such as Linux. To download and install the latest version of BaseCamp software, view this video or select your operating system below for steps.
Checking the Installed Version of BaseCamp Software
null
Updating BaseCamp Software
By default, BaseCamp software checks for updates automatically. You can also update the application manually. Before you can update, you must have an active internet connection.
NOTE: Updating BaseCamp software does not delete your stored data. However, before updating, you can create a backup file of your data to save on the computer or external drive. For steps, see - BaseCamp for Mac - Backing Up Data or BaseCamp for PC - Backing Up Data.
Experiencing Issues or Errors When Installing or Updating BaseCamp Software? Try These Troubleshooting Links:
- BaseCamp Fails to Install on a Windows Computer
- Issues Installing Certain Garmin Applications on Mac OS X
- BaseCamp installation fails "Apple cannot check for malicious software" Message
- "There is a problem with the Microsoft .NET installation" Error in BaseCamp
- App is Not Optimized for Your Mac Message
- Error "LoadLibrary Failed with Error 1114" When Opening BaseCamp
- Garmin Device Not Found by BaseCamp
