Xero Bow Sight Cannot Calibrate Past the First Pin - Stuck in a Loop
If during the calibration process for the Xero® A1, Xero® A1i, or Xero® A1i PRO bow sight you appear to be stuck in a loop and cannot calibrate past the first pin it may be due to using the Trigger Button as the OK button. This is not the intended purpose. The trigger button is only designed to be used for ranging targets and bringing up fixed pins. If the sight is asking you to select an option use the OK button on the sight. Do Not use the Trigger Button in an attempt to select any option from the display.
To get out of the loop start using the OK button. If the issue persists press and hold the PWR button until the device powers off and power the Garmin back on.
