What is the Insights Feature in Garmin Connect?
Insights on the Garmin Connect™ platform provide coaching tips to help you beat yesterday. Insights also help you understand how you compare with other users in your age range or gender. Stats are refreshed daily and may not appear immediately after syncing.
NOTE: Insights require a Garmin wearable to be associated with your account. Having just an Edge® cycling computer associated with your account will not provide Insights.
Insights can provide you information on the following types of data:
  • Cycling1
  • Floors climbed
  • Running
  • Sleep
  • Steps
  • Swimming
Insights requires certain user data in order to generate a demographic histogram, such as:
  • Age
  • Consent
  • Data
  • Gender
Once consent for Insights is granted, only new data uploaded to Connect after the date consent was granted will be able to be compared. Old data isn't reprocessed to be compared after Insights consent is granted.
NOTE: Once consent is granted data will need to be collected for at least 30 days before information will populate.
Enable Insights
Select one of the following options to reveal instructions for enrolling in Garmin Insights:
Garmin Connect App
  1. Open the Garmin Connect app.
  2. Select More (bottom right).
  3. Select Insights.
  4. Select Agree.
Failure to meet a requirement above may result in not being placed within an Insight histogram.
Garmin Connect Web
  1. From a web browser, sign into your Garmin Connect account.
  2. Select Insights from the navigation bar on the left.
  3. Select Get Insights.
  4. Select I Consent.
Garmin Connect Insights:
1 Due to average speed and power differences present with assisted eBike and eMTB activities, these profiles' are not factored into Insights.
Related
