Pairing the Garmin® GPSMAP 86i Series to a Garmin Marine Chartplotter
Certain Garmin® chartplotters may be paired with a Garmin® GPSMAP 86i handheld to do the following from the chartplotter screen:
View previous messages sent to the Garmin® GPSMAP 86i series
Reply using quick messages
Messages will be shown as notifications on the chartplotter.
The Garmin® GPSMAP 86i series must be able to acquire a satellite signal to send and receive messages. It will generally be able to acquire a satellite signal when placed in an area with a clear view of the sky.
Garmin® Chartplotters Compatible With the GPSMAP 86i Series
GPSMAP® 7x2 chartplotters| GPSMAP® 7x3 chartplotters | GPSMAP® 9x2 chartplotters | GPSMAP® 9x3 chartplotters | GPSMAP® 10x2 chartplotters | GPSMAP® 12x2 chartplotters | GPSMAP® 12x3 chartplotters | GPSMAP® 16x3 chartplotters
GPSMAP® 74xx chartplotters | GPSMAP® 76xx chartplotters
GPSMAP® 84xx chartplotters | GPSMAP® 86xx chartplotters
- GPSMAP® 90xx chartplotters | GPSMAP® 92xx chartplotters
Pairing instructions
NOTE: The system software on the Garmin® chartplotter and the GPSMAP® 86i series must be up to date before pairing the devices.
When the devices have been updated, enable ANT+ or inReach Remote on the Garmin® inReach Mini series and pair it with the chartplotter.
GPSMAP® 86i : Enabling ANT+
Open the Main Menu
Select Setup
Select Sensors
Select inReach Remote
Select On
Garmin® Chartplotter: Starting Pairing
Select Vessel from the home screen of the chartplotter
Select inReach
Select Start Pairing
The Garmin® chartplotter will show a Connected status when the pairing has been completed successfully.
