Installation Instructions and FAQs for the Rally Small Parts Kit
The Rally small parts kit is designed to provide you with replacement parts related to the battery compartment of your pedals in the event you need to replace a part due to it being lost or damaged.
What Is Included in the Kit?
Below is a breakdown of each part included in the kit.
NOTE: Replacement batteries are not included in the Small Parts Kit.
Rally Small Parts Kit Breakdown
Part Image
Part Description
Image of Vector 3 Battery Door
Battery cover
Image of Vector 3 PCB Board
Printed circuit board
Image of Vector 3 PCB Screws
Printed circuit board screws
Image of Vector 3 Spindle Seals
Inner and outer spindle seal
These are used when servicing the pedal spindles. For more details see: Overhauling the Vector Pedals
Image of Vector 3 Battery Door Seals
Replacement battery cover seals
Garmin provides you two additional battery cover seals if the one installed on the replacement cover becomes damaged.
How Do I Install the Kit?
Battery Board Replacement Tutorial:
What Type of Batteries Should I Use?
For improved performance Garmin recommends the following: Energizer® 2L76 Battery
This single coin cell battery results in only needing one for each pedal instead of two. You may only find this model of battery online or in a store that specializes in replacement batteries. For a detailed list of recommended batteries see the following: Battery Model Recommendations for Vector 3/3S or Rally Series Power Pedals
