Fusion MS-UD650 OEM Manual Software Update
Fusion MS-UD650 OEM software version 2.00.265
as of April 1, 2016
Download (9.09 MB)
View installation instructions and system requirements
Notes:
- USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
- This firmware release also contains updates for DAB+ accessories and NRX remote controls.
- Accessory software updates (MS-NRX Series/MS-DAB100A): Once the stereo is updated the connected accessory MUST be updated from the 'update' menu in the 'settings' menu to be compatible with your Fusion Entertainment System
Installation Instructions
- Insert a blank USB flash drive formatted in FAT32 with a capacity of at least 4gb and no larger than 32gb into the PC/laptop
- Download the FusionMS-UD650_200265.zip update file to the PC/laptop and open it
- Drag the Update folder onto the USB flash drive
- The Update folder should now be the only folder on the USB flash drive
- Connect the USB flash drive to the USB Port of the stereo
- On the stereo, select Menu > Settings > Update > Update Software
- The DAB+ module and remotes can now be updated from the update menu if required
System requirements
- IBM-compatible PC running Windows 2000 or later operating system and an available USB port.
