Pairing a Montana 710i/760i With the Garmin Messenger App
NOTE: This article is intended for users who have already activated an inReach® subscription for their Montana® 710i or 760i outdoor handheld. If you have not yet activated an inReach subscription for the device, see - How to Activate a Montana 710i/760i in the Garmin Messenger App.
The Garmin Messenger™ app is an Android and iOS mobile application that optimizes inReach® messaging to use the cellular connection of your compatible smartphone when it is available, then switches to 100% global Iridium® satellite connection with a compatible inReach device when you go beyond available cellular coverage range. It also allows you to control and customize certain functions and settings for the connected inReach device.
When you first set up the Garmin Messenger app, you are prompted to verify your mobile phone number on the mobile phone that will be used. From that point on, any inReach messages sent to your phone number will be routed to the Garmin Messenger app instead of your phone's default text messaging app.
The Montana handheld can be paired with one smartphone at a time, and the software on the Montana handheld may need to be updated before it can be used with the Garmin Messenger app. For instructions, see - Updating the Software on Your Outdoor Handheld With Garmin Express.
1. Setting up the Garmin Messenger App
null
2. Pairing the Montana 710i/760i Handheld
In the Garmin Messenger app, select the profile icon or
in the top left.
Select Add Device (or Devices > Add Device).
Allow any app permissions when prompted.
When powering on the Montana for the first time, you will be prompted to select a language, then activate, and it will automatically start looking for the Garmin Messenger app.
- If you are not prompted to pair with Garmin Messenger during the initial setup, update your software.
If you had skipped this previously, you can enable pairing mode on the Montana by selecting
> Setup > Pair Phone.
If your Montana is currently connected with another Garmin app on your phone, skip to step 5.
In the Garmin Messenger app, select Connect It and enter the 6 digit code from the Montana when prompted.
