Setting up the Antares and Galaxia Rollers
The assembly instructions below are for reference. They will be included in the box of your Tacx® Antares Basic Trainer and Tacx® Galaxia Advanced Roller Trainer.
NOTE: The Tacx Bike Support for Rollers is available as an optional accessory that can be purchased separately. This support secures the front of your bike to a Tacx Galaxia or Antares trainer providing extra security and stability. It is designed to work with standard 5mm axle skewers and is not compatible with thru-axles.
Review parts for assembly.
Mount the Rollers, including the belt, on the frame.
Disassemble the holder of each dowel pin (x2).
Measure the length of your bicycle from axle to axle.
Determine the position of the dowel pins that match the length of your bike from step #4 and mount it.
Unfold the handles.
Press button A in, and extend the frame to the chosen size.
Shut the handles and move belt to middle and front rollers.
