10x135mm Direct Drive Thru Axle Fitment
You will need to identify the type of axle included with your trainer. Review the following FAQ before choosing an option below: Which Type of Axle Do I Have on My Tacx Trainer?
NOTE: Most newly purchased Tacx direct drive trainers will be a Type 2 trainer. The exception would be a trainer that has sat on a shelf for an extended period of time.
Type 1 Trainer
You will need to purchased the Tacx Direct Drive Quick Release With Adapter Set - Part # T2840
Type 2 Trainer
You will need to purchase the following to mount your bike to the trainer: Direct Drive Quick Release with Adapter Set
