You are viewing an article that is not available in your currently selected language. You can choose another one below.
Garmin Autopilot Software Update
Garmin periodically releases software updates for devices, which improve performance and add functionality.
To update the software on an autopilot, connect the autopilot to a Garmin chartplotter over NMEA 2000. When a software update is installed on the chartplotter, all compatible Garmin devices in the network will then be updated as well. For information on how to update the device using a chartplotter, review the related content.
If a chartplotter is not available, see: Using the Garmin NMEA 2000 Network Updater Using the Garmin NMEA 2000 Network Updater
