Index BPM Measurement Taken When Not in Wi-Fi Range
Index BPM can store hundreds of measurements and can be manually synced while in range of a configured Wi-Fi network by walking through the steps below.
  1. Ensure you are in range of a configured Wi-Fi network.
  2. Wake the device by pressing any button.
  3. Press the Three Horizontal Lines button twice.
  4. Press the Heart button.
You can also take a new blood pressure measurement and, if the device is within range of your configured Wi-Fi network, it will sync both your new measurement and all the stored measurements.
If the device is within range of the smartphone used to set up the device, the primary user’s data can be synced via Bluetooth via the Garmin Connect mobile app. However, any other users’ data will will only be synced the next time the device is within range of a configured Wi-Fi network, following the instructions above.
