Viewing HuntView Maps on BaseCamp
BaseCamp™ software is not designed to read multiple map layers at one time the way our HuntView or HuntView Plus compatible outdoor devices are.
However if you connect a device that has a HuntView map loaded, you can still see most of the HuntView map information by using the select map option in BaseCamp program to switch between the map layers.
Viewing and Switching BaseCamp Software Map Layers
- Connect device with HuntView Map installed, or insert HuntView map SD card into the computer
- Open BaseCamp program
- Select Maps
- Select the Map Information you want to view - HuntView Plus Map Features and Legend Information
- HuntView Topo - Shows the Topographic, Road and Land Status information
- HuntView Parcel - Shows only a basic map and the landownership boundaries with the owner name if available
- HMU (only available on HuntView Plus maps) - Boundary lines will not show in BaseCamp software
- See Related content at the bottom of the page for instructions on viewing the information on compatible handheld
Viewing BirdsEye Satellite Imagery in BaseCamp Software
- PC - Select Show/Hide Overlay box (bottom left corner of BaseCamp program map image)
- Mac - Select Show Overlay check box (bottom of BaseCamp™ map image)
Why Can't I see the HuntView Map Information?
- Check your zoom level - You may need to zoom in closer to see the detailed information
